RCLumens
Comparison info requested - Jetbeam RRT-3 Triple XM (Apples) & Olight SR51 (Oranges)
Greetings all - This question is perhaps aimed at those who have both kinds of lights as we are comparing apples to oranges... The question itself is about which light winds up on the shelf, or being used the most...
Single XML's can be smaller, or larger and throw further, but the triple xml's have such a nice contrast between spill & throw comparatively, but are usually larger. Outside the TM of course, but then you sacrifice throw, and heat driving down output... Is the Jetbeam RRT 3 the perfect balance? Size not much bigger than the SR51, weight not much more, spill beam substantially greater, but doesn't throw as far... If anyone has experience with both these lights, I'd be curious to know which one winds up being used more, and which one is being used less...
Perhaps we'll have to wait to see if Sunwayman will come out with the V60C triple XML that will provide solid run time, beam spill & throw all without succumbing to heat?? All within a reasonable price perhaps?
Thus far no one has stepped up to send selfbuilt the light for proper test, and am interested in hearing any thoughts on the subject.
Many thanks!
Many thanks!
