surefire 9p
adam38654
I tried searching but the search term is to common and short to go threw.
I am thinking about buying one of these and upgrading it to LED and possibly rechargeable batteries and wondering what my options would be.
Does 3 cell's increase the voltage or the run time considerably?
adam38654
So 3 regular 123 cells is pushing 9v ? Do all rechargeables need the tube bored out?
flashlight chronic
Kapolei, HI
There are many LED drop-ins available for the 9P, but if you want to run rechargeables in the stock (non-bored) body, then your choices are small. You can run 3 rechargeable cr123's, 3x16340 li-ion's or 2x17500 li-ion's. Boring the body to accept 18mm cells is another option also. Choosing what batteries to run will help determine what voltage rating you need to look for when choosing a particular LED drop-in. I have a 9P w/ a Malkoff M91 that's bored to accept 2x18500 cells, if that helps!:grin2:
ElectronGuru
Oregon
2 18500s are not significantly more in capacity than 1 high capacity 18650. The primary advantage of the 9p then, is the extra voltage. So start with your drop in choice and go from there.
HotWire
Check the Lumens Factory LED for D26 13v. That and 3 RCR123 should do what you would like. You could also check LF for brighter incandescent bulbs and go from there. Enjoy!
adam38654
Thanks, Ill try that. I forgot about the lumens factory bulbs. They look more quality than the solarforce or ebay ones.
How would the 3-mode bulb work with a twist cap with momentary switch?
What lumens is the LF XP-G R5 D26 putting out?
Beastmaster
Phoenix, AZ
I own a 9z with a Malkoff drop in. It's a great upgrade. Contact him.
As for runtime - no increase for me. Definite increase in output.
Sent from my HTC Glacier using Tapatalk
