nuclearpenguin
- Joined
- Jan 22, 2012
- Messages
- 3
This is not a review, I am just frustrated and wondered if anyone else has had these issues.
Just purchased an Olight M3X for use on the farm as a weapon light or just a thrower to see what is going on out there in the big dark.
After being pleased with my Olight M20S, I had high hopes for this light, but was very disappointed with what I received. Product was packaged well in a nice case and went together easily by following the instructions. I had just charged up some new batteries (Ultrafire 3100mah) and put them in using the extender tube. Light came on bright but when I loosened the front a quarter turn or so as instructed to shift modes the light quit working. I took it apart and ensured I had followed instructions and a piece fell out off of the emitter (small plastic ring - supposed to be glued on around the emitter it appears). I managed to get the ring back where it belongs (it is held on by reflector) but the light still does not work reliably. If it gets bumped it will quit. I can get it working again if I take it apart and put it back together...sometimes. You have to shake it to get it to work in many cases. If I shift to low or to strobe, half the time it just quits and requires minutes of fiddling with it until it works again. If I remove the batteries and re-install, same story.
I am also unhappy with the beam. I researched this light and it is described as a great thrower with a tight beam...not my experience. I shine it a a white wall 5 feet a way and see a flower shaped hot spot. Out to 20 feet and it is a hollow flower with a dark middle. Out to longer distances I get some light out there, but not a really tight beam. So much for distance. I get 200 meters maximum from this and that just barely. Product is described on box as being good out to 800m...not a chance that is close to accurate.
I had wanted to put this on my AR-15 for use on coyotes but that is out. If I bump it, it stops working half the time until I do the flashlight dance. I can't imagine it would survive even mounted on a 22lr.
Just so you don't think I am a moron and can't figure out how to properly assemble a flashlight. I was trained as an Electrician in the US Navy,spent 8 years as a nuclear engineer before being bored with it, and am now a telecom/it architect. I have built working cars from junkyard parts. I am pretty sure that the issues I am having are not operator related.
Unless someone knows a trick to get this thing working reliably, I am likely going to return this to Amazon and buy a Crelant 7GS, or Thrunight Catapult from some website in China (don't mind China at all, they were nice when I visited there, it just extends the shipping time a bit). Maybe someone else will get it right for half the money that this Olight cost.
If anyone has any suggestions I am open to trying them, but my frustration level is already high.
