(Sorry for the poor pictures) http://imgur.com/a/Fizae
As you can see I have a damaged Fenix E01 with white goop oozing out from the bottom of the head. It had been powered by an Energizer alkaline battery that was brand new when installed, with an expiration date of 03 2015. I last used the light 3 or 4 days ago and it has worked flawlessly since the Oct 23, 2011 date of purchase. When I attempted to twist the head to the on position this evening I was unable to turn the head. I grabbed some pliers and used force to twist the head off. Just before the head completed clearing the threads I heard a surprisingly loud "pop", and as I examined the head I noticed the white goop starting to seep out. There appears to be no damage what so ever to the Energizer battery. I'm not going to test it in another device for obvious reasons but the shell appears unharmed and free of any type of foreign material.
EDIT: Oh, one last thing. There was not "burning" or other "hot" or mechanical smell when I took the head off, if that helps or matters.
Obvious questions.
1. Can I wipe the head clean and try powering the battery on. I'm a little reluctant to even mess with it at the moment as I assume the goop is potentially harmful. I assume the LED was destroyed. Gas buildup??
2. Has anyone used Fenix's warranty service? Good? Bad? I read over their policy and it says to contact the dealer for a warranty claim. I purchased from Amazon and I'm guessing they won't deal with the matter from a repair standpoint, but they might simply replace the unit. I know some battery manufacturers will cover incidents where there battery causes damage, but I doubt I have a claim with Energizer.
3. Can I have some recommendations for single 3AAA alternatives. Naturally I'm a little reluctant to purchase a Fenix again if I can't get any type of warranty service. I'm well within the 24 month warranty period but you never know.
Ironically I have AAA eneloops that I purchased at the same time as the light but I had a single AAA battery left from a 4 pack in my desk and decided to use it first then switch to the eneloops when it gave out. It was in the lite since the Oct delivery. If it was a gas buildup, Eneloops don't discharge gas (from what I've discovered on the forums), so had I used one in the Fenix I wouldn't be looking for advice now.
Thanks for any advice offered.
Obvious questions.
