Some bloke
Hi, I have a superfire 6P? LED torch. I have tried an IR drop in module in it for use with a homebrew Watec 902H camera based night vision device. I only use the torch for a few seconds at a time by virtue of a remote pressure switch so I am not very concerned about any heat build up. I spot the quarry with another device.
The IR module has sufficient range for my FAC power air rifle needs but the splash swamps the near ground which ruins the plot really. I'd like to find a collimater, ideally a ready made one, but I am fairly adept at fiddling with small things and would be able to put something together if that's what I have to do.
Whats available please gentlemen - I am in the UK.
I have found this item on the bay: which is Item number: 260968042988 if the link doesn't work. Would it be as simple a trick as to fix the lens to the end a 30mm tube and slide it onto the bezel?
Thanks all, Dave.
Thanks all, Dave.
