I would like to start a thread & see if there's anyone started modding the new Mag C leds yet?
I have some loose photos scatted around, on slight modding but have not committed to gut it open for some serious power. It's got potential to beat Surefire M3LT/M6LT with same TIR Beam.
Here is my ML100 2C cut-down to 1C, it now runs on 18650 for a couple month now. No issues.
The stock light throws very well, but with a real tiny hot spot. I now converted the light to run on a large 45mm TIR lens, Gaggione LLC49R.
If converted to XML 2.8Amp set-up, or even a XPG/2.0Amp set-up, this set-up has potential to go up against M3LT/M6LT. With same type of TIR beam. The beam in my light is nearly flawless, a good sized hotspot with no spill, just not enough intensity to my liking.
Even just bump up the driving current on the stock XPE would be nice, but the driver & new electronic switch is a unchartered area.
However, this is where tings gets iffy. The ML100 has a complex head that's not easy to convert to
typical mag heat sink set-up.
I am wondering if anyone planning to take the first jump into this area? I am not interested in putting this 45mm lens in regular mag & a spacer, just doesn't look right to my.
