Grmnracing
I have a Quark X aa^2. The 280 max lumen XML version.
If I ran a 14500 in the single tube will it be brighter than 2 AA's?
I have tested both with a lux meter doing a ceiling bounce test and they are the exact same brightness on Max.
If you run any of those on a 14500 you'll get the output of a Quark 123 and the same runtime as a Quark 123 running on an RCR123. They are the same, but output/runtime vary depending on battery.
Actually, in a large majority of cases 14500s will have greater capacity than 16340/RCR123s, due to the greater volume of the AA size. It's seems conventional wisdom, and often tesed here on CPF, that the stated 750mah capacity is reasonable correct for 14500 and a significant overstatement for 16340s.
This will vary from brand to brand, though. I never did side-to-side runtime tests, but the outputs are definitely the same.
What was the verdict? Does it have a higher out put or not? I am interested in doing the same thing.
