I have 4 lamp assemblies that consist of 3 separate boards each. Each board is populated with 4 x Cree MC-E'S with all diodes connected in series, and the 3 boards are connected in series, so thats 16 in series for each assembly. ~120W per assembly.
My power source is a generator that I can get either 50-130v DC , or 120V AC
The original drivers (x4, 1 per assembly) operate on 40-60v DC and output 100-200v for each assembly (16x MC-E's in series)
I burned the original drivers yesterday by accidentally starting the generator with the lamps on. The gen has to start at a higher RPM, which means higher voltage. At starting the DC output is ~90v, and the drivers caught fire.
I could drive each assembly with a single driver as the original, or I wouldnt be opposed to re-wiring the assemblies so there are 3 separate drivers per assembly, 1 driver per board.
I guess each board would need a supply of >~54v @700ma, if I go separate drivers per board. If I drive the 3 boards in series as it was, I guess I would need a driver that will do >~160v at @700ma.
I cannot find any reasonable 54v drivers. All I can find are 36v max. I found some MeanWell 54v 120W drivers but they are expensive.
I am looking for recommendations for replacing the drivers, in whatever configuration is cheapest. I have looked all over the web and havent really came across anything. I cant get originals as they were a prototype build, and the company that built them for me is no longer building LED drivers, and they have none to supply.
I have pics of the assemblies if it will help.
Any help is MUCH appreciated. THANKS!!! in advance.
