Closed: Magnetic Rotary Switch Mag 1C HIgh CRI Neutral Nichia 219
Closed
is a unique hand made mag that I've wanted to put together for quite some time, just wasn't able to figure out how.
Finally, I think this might qualify me to work in Maglite Instrument R&D dept.?
I am never interested in making the same thing twice, so here it is, for the true mag lover, I proudly introduce the one & only, Magnetic control ringed total stealthy mag 1C.
Asking only $189. Now $179 169 $159
$ 9 shipping in USA. Int. OK at additional cost.
Closed
- Mag 2C being cut down to 1C.
- Stealthy looking, a wolf under sheep's skin
- Magnetic control ring is sealed & rotate outside the body.
- seals better than OE due to removal of clicky boot, the weakest link
- Instant access to HI to one direction & instant access to SOS to the other direction
- 3 mode Hi/Med/Lo on one direction, two blinky mode to the other direction
- Tasteful Teardrop separator between modes
- One does not need to go through blinky to access Hi/med/lo
- Total 360 rotation to go through all 5 modes also possible
- Nichia 92CRI 219 Netual led
- Mag Rebel SMO reflector -Spatted to partial OP for better beam
- Built-in black Alu battery spacer for 18650
- Recessed spring for shorter length
- >3hr run time on high with high capacity quality 18650
