I can't speak to run time yet but I did get the MT 26 today! My initial impressions are as follows:
First impressions are that it is a good size not too heavy and it comes with a sheath.
The 18650 battery fits great wth no rattle at all.
It is daytime here (NC) but my bathroom is very dark! OK, it's a very bright light.
My eyes before looking into the light - (00), my eyes after looking into the light - (~~) !
My brightest light to compare it to is the Surfire LX2 at 200 lumens it can spot the tree tops pretty easily.
The MT 26 looks like at least 3x or 4x brighter. So on an estimate it looks like it is putting out 700 to 800 lumens.
The LX2 has a very defined hot spot which is why I use a diffuser with it. The MT 26 also has a defined hot spot but it also has a lot of side throw which the LX2 does not. I will not know how much of a spill it is until I can use it outdoors at night. My guess is that it is quite nice, at least it is against a wall on the other side of the room.
I am not a fan of smooth reflectors which the MT 26 has but it seems to power through any bad effects. This really is my only down side to the light there are some different shades from the hot spot to the outer areas although they are not too defined
I believe an orange peel reflector would be nice. I'm no expert and I'm not even sure they can do it with this light but the ones that I have with textured reflectors have a much nicer beam. Perhaps they would loose throw or something with a different reflector.
So, to sum up, very bright, very comfortable and a good beam which could be even better perhaps. I would give this light a solid 4.25 out of 5 stars!
I plan on using this light very hard and with the rechargable 18650 batteries it may even be given a higher number. Only the night will tell...
2bright
