So I pulled the trigger on the Ed20 in T5 Neutral. It arrived today from hkequipment and immediately failed on me out of the box, brand new. As soon as I entered high mode, the light started to flicker consistantly to varying degrees (not PWM). If I leave it on high for a bit, it seems to get better. I have cleaned all the threads and contact points with 70% rubbing alcohol, and checked to make sure the switch inside the tail cap was screwed in tight. I believe the switch might be faulty, what else could there be? I'm new to flashlights, so I might have overlooked something.
There is also a very slight movement with the circuit board located in the head. This movement, although very slight, makes me a little uneasy. Is this normal? I hope Selfbuilt still follows up on his older threads. :mecry: Can someone confirm this slight movement with me? Contacting Lumintop regarding these problems, I will post updates to their customer service.
