Its a significantly dark small hole in the center of the beam. I will try to get some pictures.
Here are a few things you can do:
1. Light off. Make sure there is not dirt on the lens.
2. Light off. Use a very low mode from another light and examine the reflector to make sure there is no dirt or damage to the reflector. Make sure the reflector is shinny and clean all over, especially no chipping or cracking in any of the edges.
3. This is a little tricky since LD20 does not have a moonlight mode. Find a magnifier of 3x to 6x (otherwise try any magnifier you can find). Turn light on and put the magnifier in front of the lens. Shine the light at a wall and try putting the magnifier at different distances (bud right up to the lens to like a few inches away) to focus the LED into a true image. When you get the right distance, you will see the square LED image projected to the wall. You should see an enlarged image of the actual LED with some hair lines in the LED. Once you find the distance to project the LED image, try different brightness on the light. This is the last test. If you see any dark spot on the LED or if the different sections of the LED appears to be in different brightness, there is your problem. Don't worry about the hair line dividers, they are supposed to be there.
If all 3 of above turns out good, it is still possible that you have a defective reflector that the cup shape is somehow defective to a point that the beam creates a much darker spot within the hot spot. Take a picture and post it here. If other people agree that it is normal, then it is your judgement call whether to return the light because you are unhappy with the light pattern.
