LilKevin715
Disclaimer: Modifying your Eagletac LED module will void your warranty! Don't blame me if you ruin your module!
Inspired by kreisler's post of taking apart his T20C2 MKII XM-L module... boredom and curiosity got the better of me and I decided to disassemble my old unused module. I've upgraded my P20A2 MKII to a XM-L NW module, so my old original XP-G CW R5 module was sitting unused. The P20A2 MKII and the P20C2 MKII modules are the same size, the only difference is the driver used. The T20C2 MKII is slightly different as it is physically larger, but the overall construction is very similar. Now on to the good stuff...
The first step is to get some clear packaging tape to protect the reflector.
Next up is to remove the C-ring and the spring.
Grab two wrenches with grip teeth, strap wrenches probably wont provide a good enough grip. Make sure that the wrench used to grip the lower portion of the module is skinny enough so that you do not grip onto the threads! Turn the reflector to the right to start the process...
On my module there was red loctite on the threads... grrrr!
Finally we have access to the LED. Eagletac used a centering shim to help center the LED in the reflector.:thumbsup:
For those that are curious the pill can take a mcpcb up to 14mm in diameter. The XP-G mcpcb measured 12.75mm in diameter and 1.7mm in thickness.
I tried to pry out/loose the LED mcpcb with a flat-head screwdriver and sadly it wouldn't budge. It appears Eagletac used a thermal epoxy, possibly Arctic Alumina, to secure the LED mcpcb to the pill. I really tried as hard as I could without making a dent into the threads on the pill. I wanted to swap the XP-G R5 out for a XP-G2, I guess it won't happen on this particular module.:mecry:To be fair to Eagletac they probably didn't design their LED modules to be dissasembled.
Update: I managed to remove the mcpcb, see post #3 for details.
Update #2: I've finished modding the P20A2 module, see post #7 for details.
The LED couldn't be removed on my module, but the driver was pretty easy to take out. Just use a small screwdriver to pry out the driver (friction/press fit).
Update: I've disassembled a T20C2 MKII module, see post #6 for details.
Thats about it for now. After going through the disassembly process would I recommend it? Probably not unless you have very specific modding needs/goals. The modules themselves aren't that expensive considering the convenience you get with them. However for the DIY'er I do have to admit it is fun taking them apart. I do have future plans for my T20C2 MKII... How does a XP-G2 R5 LED with a XM-L driver (2.1A turbo boost, 1.5A after) sound ?:devil:
