The only lights I've found that fit my keychain form-factor requirements are:
Veleno Quantum D2/DD
Preon P0
Klarus MiX5
(and MBI Torpedo if it gets produced! I'd be willing to increase my dimension limits on a keychain light slightly if it had a 500lm turbo, wow)
Each one seems to have pros and cons.
Preon P0: tiny and just ~$20, uses common battery with decent capacity, but bad runtime for a AAA (1.5 hrs on 25 lumens while the slightly larger AAA klarus x6 gets 6 hrs on 26 lumens?) and no high setting
Klarus x5: Cool form factor, bit long but super-thin, and has a good high. But has the drawback of being impossible to locate except in Gold, and I need black or silver color.
Quantum D2: love the form-factor plus it's in stock unlike the Klarus, but I have the following questions and I don't have enough posts on CPF to PM Steve Ku, so:
1) 90 mAh capacity on the 10180 battery seems miniscule compared to AAA or AAAA. Using the DD or D2 on a usable medium, say ~30 lumems, what runtimes are you getting?
2) With say 15 min of medium and one or two brief turbo's, will the battery last all day or do I need to carry a spare? Edit actually I'm getting a portable USB battery pack, the mophie juicepack, for my tablet so this should work, still would be a pain to recharge more than once a day tho.
3) Someone said they needed to replace the 10180 battery after a month, someone else said they didn't even need to recharge it for a month. With avg keychain light use, how often do you D2 or DD users recharge? How often do you buy a new 10180 altogether?
4) How often does the QTC thing and o-rings need to be replaced?
5) Can I (trit newb) do my own tritium inserts with the Quantum D2 or DD, or should I order them pre-installed?
6) Where do the trit inserts fit exactly, in the fin-things by the tail? How many can fit at one time?
Thx in advance for any responses!
Preon P0
Klarus MiX5
