Dirtbasher
Hi , fellow XT11 owners , I am a little concerned about using a 70mm 18650 battery , the reason is the inside battery compartment measures approx 71 mm, leaving very little spring tension with a 70 mm battery,
My XT11 came with a battery from the dealer, same colour as the Klarus box with a K-01 marking, but they probably don't realize the length tolerances inside.
My thoughts are over time the battery compartment springs will loose tension as they are no doubt squashed flat out, anyone else have the same concerns?
