Hi all !
Thaks WalterK , have allready read , very usefull !
Problem is simple .... all my led diving lights are based on SST-90 emiter ( high lumen output , high surface brightness , very robust led also could use for video if change inner focus on
screw ) , in housing which is
limited with 50,5mm in diameter ( in length I have little reserve ) I also use DX aspherics lens with 44 mm (40mm without edge ) and focus at 18mm. Led is
driven at 10A.
Light is powerful and bright tight beam (cca 7° ) , but somewhere beyond 5 m, the beam suddenly extended ( like some funnel ) , which
I think is problem of bigger die and small aspherics
lens.
I know mantra ( smaller die , bigger lens diameter , deeper reflector ,....) . But I like to correct that on existing system as much as it is possible.
I don't have picture at the moment but it is similar to that video
http://www.vielviellicht.de/ just that led expands very fast cca 30 cm.
Mine do that some 1,5m away ( still have at 1m square 16x16cm and at 5m square 63x63cm , but it highlight a house next to me in distance cca 10m at least 4 m x 4 m .
I don't need some long throw , but I need powerfull beam on short distance ( 30m ) to penetrate murky water and beam must be '' slim formed ''
I'm looking on several sides like :
http://www.wavien.com/shop/rlt-collars/rlt-collar/ which I think would form tighter exit beam ( from 120° to 28° (small with 12.5mm aperture , because 32mm is outer
diameter and I have 50mm frensell lens with I think 35mm focus ) ....... personal I have mixed feelings :-(
I also don't like dedooming special SST-90 have many bonds , and I dont like to burn out phosphorus :-(
