Let me add this too. I need this light for the throw too, but this thing is nowhere near 308 meters. I get great light within 100 meters. Anything further than that isn't really gonna work. I can see easily that this light will light up a reflective street sign 300 meters down the road, but you won't really get light out that far with this. It seems like the emitter could be pushed a bit more, but what do I know. Im still learning too, but I can count meters, and this thing works pretty great but for about 100 meters, but if you need more reach or lux after that, I would say try a different light. Good to see the opinions of this light are all over the place though.
dave
One thing it takes getting used to is INTERPRETATION of specs....
The specs for a light's out put involve Lumens (The total light send out the front) and the cd, which tells you the lux on a target at a given range.
The ANSI Specs, the ones all the makers include, DO help in comparisons, as at least they are all using the same measurement protocols and units....
BUT
The ANSI spec for throw is the range, in meters, that the beam intensity has dropped to 0.25 lux.
So, the intensity drops with range according to the inverse square law, meaning its essentially 4x dimmer at double the distance.
Now, close up, if your eyes are night adapted, you can see ok with 0.25 lux on what you are looking at. The problems with seeing things far away, is that to resolve details of distant objects, you need to use a small part of your cone of vision, and that small part (~ a 2º cone) has TERRIBLE night vision, poor motion tracking, etc....its almost night blind.
This is why you can look right AT something in a very dim room, and not see it, but, if you look to the side of it, you WILL see it with your peripheral vision...which sees in darkness more easily.
So, when you get out to ranges closer to the 200 meter range and on, vs closer than 100 meters, etc....you start to need proportionally more and more lux on the same object to be able to resolve it.
At ~ 200 meters or so, 0.25 lux is about enough to see the beam itself glowing off in the distance, but not typically enough to tell what's IN the beam per se. IE: You see the beam is ON something...and that's about it.
Most of us need closer to 1 - 5 lux to resolve details at the 200 - 300 meter range, and, a low contrast target can need many times that.
When calibrating shooting ranges for night shooting, guys could barely aim at high contrast paper targets at 200 M with ~ 1 lux, but could not even FIND rusty steel targets (Low contrast) at the same distance with 15 lux.
So when looking at the cd ratings of the lights, keep in mind that they were used to tell you the "Range in Meters", or, further calculated to show the range in yards (Sounds like a larger number, must be even better...) BASED upon the throw to that dim 0.25 lux spec
So if a light is rated at 23,256 cd, that means its giving you ~ 1 lux at ~ 150 meters.
Your observation that you were fine with it at 100 M or less means you are OK with closer to 2.3 lux as a reasonable level of illumination. (This puts YOU squarely in the fat part of the bell curve for the need for 1 - 5 lux at that range, right in the mid-pack range)
If you WANT ~ 2.3 lux on something ~ 300 meters away, that requires a much more powerful light....about 210,000 cd, WAY beyond what a SRT7 sized light can do on a practical basis.
You'd be looking at an aspherical light that put a small spot of light on distant targets, and/or a larger triple or quadruple 18650 powered light with a relatively large reflector, etc. At leas t in form factor if not in specifics.
The Olight SRT95U for example would be a stock light that could do that....for quite a few hundred $.
Vihn makes quite a few things that could do that, for hundreds less. Saabluster and other can do that too, for example the DEFTX has an over ONE MILLION cd rating, and is about the furthest throwing LED flashlight you can buy right now.
But a small flashlight that is powered by one 18650 in size, etc...is not going to get you there with a beam large enough to be very useful at least.
