Not my type, it's very annoying when you need momentary for a little longer than a few seconds (you need to press and hold firmly otherwise it will change mode). And to change mode you need to turn your light off, change mode and turn back on. 3 presses instead of one...
It's natural for Ultrafire. If you're using it mostly on high, mode sequence is not so important. But if you use your flashlight mostly on low (most people do) and need some more light, you have to go directly to the highest mode instead of medium (which you need). If you're on low with momentary and accidently release the switch (slightly, just enough to switch it off), when you press it again it will blind you on high. Low-> Mid -> High is even more natural and suitable for more users.I agree that High -> Mid -> Low is just un-natural and an abomination!
Isn't TK11 discontinued? It came out 3 years ago. If it is I can see no overlapping. I had Predator a while ago and sold it - it's much bigger than TK11/12/15 and has too tight spill which made it unusdeable for me as a EDC.Seems like Fenix is getting a lot of overlap in the capabilities of the TK lineup. Unless they plan on dropping some older models. . . But since I just bought a ArmyTek Predator i don't think I'll be needing another pocket thrower for a while!
I
HOLY SWEET MOTHER OF BEJEZZUS!
I've been waiting for this moment for quite a while. But there was an "old" TK12, right? seeing this confused the heck out of me for a second. Why didn't they name it the TK13?
I'm kind of dissapointed that it doesn't appear to use the new "lossless OP reflector". Or at least I didn't see that it does. And is this a new style of switch or is it basically the same functionality the original LD20 had but with momentary now?
And kind of important in my opinion too: does it tailstand? I like the idea of the tail cap being recessed just far enough so that it can tailstand and thus is slightly more protected when taking a fall onto a hard surface.
I'm glad this version won't be using a head twist to change modes. It's the reason this happened: http://www.candlepowerforums.com/vb/showthread.php?370471-Fenix-TK11-R5-Glue-Problem
EDIT: Interesting to see this TK12 is actually slightly lighter than the TK11.
Weird, based on the description on Fenix website it seems like a hybrid forward/reverse clicky...
And guys, remember that if this is a "tactical" model, it typically is supposed to come on in high mode first.
That was my interpretation of the UI ......once I got my head around the fact that I hadn't hopped on a dusty thread and checked the Fenix site. The title and first post kinda stunned me! :huh:
Oh yeah i did not think of that thanks!I don't think so. It wouldn't recognize the difference between "tap" to change modes and "click" to turn it off.
