Sold/Expired WTB: High Current AA to D cell adapters for 4D Maglite (stock size) [shipp to Norway]
Zepticon
Hello :)
Im looking to get my hands on two sets of high current D-cell adapters for a 4D maglite. Any configuration is interesting, but i need atleast 8V to the driver using AA batteries.
Let me know if you have anything that might be usefull
Hallis
Dallas, Tx
even in a 12aa/4d holder you'll be up around 14.4v on NiMH rechargables. Might need to pick up a few dummy cells if you need to get down to 8v. Might be equally as feasible to use eight 1/2D cells for 9.6v.
fivemega
California
You mentioned "AT LEAST" 8 volt but what is the maximum voltage?
You may consider about
16AA in bored out 4D Mg.
Nominally 1/2D cells are actually 36mm long. Therefore 8 won't fit in 4D M*g and 7 will fit if tail cap is modified.
Zepticon
I dont have equipment to get the mag bored. And getting it done proffesional would be insanely expensive in norway :D
The minimal voltage is about 8-9V and maximum is 21V. Its going to use 6600mA at max load.
And the reason i posted here was because i am looking for either a fivemega or mdocod adapters used :)
What modifications are needed to the tail cap for the 7x 1/2D to fit?
Zepticon
Now that is interesting!
Those 38mm adapters, are they smoth surfaced or "gripped" like the middle of the light? If they are smooth, then they are the best option i have seen so far.
Is there a tutorial somewhere regarding how to bore the cap? I have access to a lathe so i can get that done if need be.
But will 7x 1/2D cells be able to handle the drain??
fivemega
California
:confused:
You need to bore out inside tail cap so spring gets further in.
Its going to use 6600mA at max load. But will 7x 1/2D cells be able to handle the drain??
3500Ah 1/2D cells are capable of that load.
Those 38mm adapters, are they smooth surfaced or "gripped" like the middle of the light?
They are griped (knurled).
Zepticon
Ahh.. I would prefer to keep the smooth end surface. I am a sucker for aesthetics (thats why i got a mag).
I have access to a lathe, but it does not have the equipment to bore the inside of the mag all the way in. But the cap is so "short" i can get it done with a regular iron.
This has been enlightning. Thanks a lot! I will try the end cap mod, and if that doesnt work, i will have to get creative.
Where do you recomend me to get those 3500Ah 1/2D cells? Any quality brands?
