Official data
Features
• Brand new ergonomic design allows easy operation with just one hand;
• Brand new switch design with an enlarged and recessed main switch making it easy to find and hard to activate accidentally;
• Brand New custom KLARUS 2600mAh 3.7V rechargeable Li-ion battery, using Samsung cells and a unique contact design that automatically aligns positive/negative current regardless of battery orientation;
• Upgraded CREE XM-L2-U2 LED, now delivering a maximum output of 930 ANSI lumens;
• Tripod mountable via the standard UNC1/4′ -20 threaded mounting point;
• Specially designed magnetic charging port. When the charging cable is within 1cm of the charging port it self-locates to make the connection. The charging cable can be removed quickly and safely at any time, which makes it an effective flashlight to use in rapid response situations;
• Uses a USB interface chargeable design, so you can charge in the home, office, airport, vehicle, etc. Basically, anywhere that has a USB interface;
• Low loss, high intensity, portable USB charging cable;
• Strobe can be activated when the flashlight is on or off, giving instant access to a blinding strobe from any mode;
• Three lighting modes with memory function make it adaptable for different situations;
• Detachable stainless steel strike bezel protects the lens and has a self-defense purpose;
• Color filters and a diffuser can be securely attached; screwed-in to replace the bezel;
• Waterproof to IPX-8 Standard (underwater to 2 meters);
Specification
• CREE XM-L2 U2 LED with a lifespan of up to 50,000 hours;
• Four lighting modes: High/Medium/Low/Strobe;
• Working Voltage: 3.0V - 8.4V;
• Battery compatibility: 2x CR123A / 1x 18650 (any 18650 battery with PCB protection)Warning: Only use the supplied KLARUS custom 18650 battery when charging the light directly (using the magnetic charging cable). All other batteries must be taken out to recharge;
• Charging: Input: 5 V; Output 4.2V/500 mA Max;
• Charging time: 7 hours;
• Body color: Military grey;
• Reflector: Textured orange peel reflector;
• Lens: Toughened ultra-clear glass;
• Dimensions: 160mm (Length) x 35mm (Head) x 25.4mm (Body);
• Net weight: 160g (Excluding battery);
• Included accessories: 18650 battery, holster, lanyard, body clip, USB charging cable and two spare o-rings;
Note: The above-mentioned parameters are approximate and may vary between flashlights, batteries and environments;
Lumen data and runtime was achieved using KLARUS 2600mAh 18650 batteries;
Weight 199.9g, Length: 159.18mm,Width:35.00mm
[/URL][/IMG]
[/URL][/IMG]
[/URL][/IMG]
[/URL][/IMG]
[/URL][/IMG]
Features
Specification
