Jetbeam TCR10 repair
GaryCliff
Looking for someone to repair a jetbeam tcr10. Only bought it last month and when trying to take the battery out I unscrewed the head which broke the wires going into the led. There isn't enough wire to solder to and I can't figure out how to split the head.
I live in the UK so it would be handier if I could get someone in here to fix it. I can post pictures if required.
Thanks
Gary
Fireclaw18
OUCH!
It's probably toast.
I had this happen when I tried disassembling one of my Jetbeams. The head is composed of 3 sections: (a) the bezel ring which holds the lens and retainer, (b) the upper head which holds the star above the control ring, and (c) the lower head, below the control ring which holds the driver.
If the upper head and lower head are unscrewed from each other they will torque the driver wires and break them. Before disassembly, it is critical to first desolder the driver wires from the star and then completely remove the driver. It's held in with a screwed in contact plate. In my Jetbeam the upper and lower held were glued with red loctite. A lot of force was required to break the loctite so having it unscrew when trying to change the battery was very unlikely.
When the wires are torqued they break at the driver. The driver itself is a 2-board sandwich. the driver wires actually pass through small holes in the upper board to get to their contact points on the lower board in the middle of the sandwich. When the wires are torqued, they break internally at these tiny pass-throughs in the middle of the sandwich. Even worse, it's almost impossible to replace these wires. A soldering iron won't fit through the pass throughs, so it's not possible to solder fresh wires on, you simply can't get to the contact points. To fix it, you might need to disassemble the sandwich. But doing that would require desoldering multiple SMDs simultaneously
I've modded drivers before, including attaching and removing regulator chips and resistors. But I concluded that the broken driver wires in this driver were well beyond my ability to fix.
Good luck with your repair.
Fichtenelch
Germany
Actually i had the same issue with my tcr10, i read your problem before i disassembled mine. couldn't turn the selector ring anymore, had it for only 2 days. ended up ripping the wires while trying to disassemble.
but i contacted jetbeam, shipped it to them mid of january and today i got it in the mail by dhl express. total cost was 7€ for me. Good Service, Jetbeam!
