Hi All, its been a while since I've been around or posted. Alaric, congrats on the promotion.
Thanks!
So, my brother never complained about the headlights on his truck, but apparently GM has been hit by a law suit over their truck headlights.
A tenuous suit if I ever saw one.
According to court documents, the trucks were fitted with a single bulb for low and high beams, rather than three bulbs normally used for fog lights, low- and high-beam lights.
My '95 Previa has a single bulb for high/low functions. My '87 Corolla had a single bulb. My '76 Corolla wagon and my '65 Dart each had a single bulb (sealed beams). Guess what? All of them complied with the legal requirements. The GM headlamps also comply with the legal requirements.
The only real difference is that these "single bulb" lamps also have a single
filament, but in other single-bulb, dual-filament systems, the filaments aren't burning at the same time.
And the mentioning of fog lamps? Those aren't for normal driving, and are almost surely available equipment on the GMC Sierra-- probably standard at certain trim levels.
This lawsuit is a non-starter.
And, as -Virgil- has pointed out, there's a TSB for flashing the BCM to increase the voltage to the bulbs. The original voltage probably reduced warranty claims on the bulbs (despite being a wear item). The so-called "upgrade bulbs" are probably just regular HIR2, but I've seen some marked as +30 bulbs.
-Virgil-, if the HIR2+30 bulbs are legit, let us know. I might have to give the '01 a little bonus upgrade
