I'm getting tired of never finding a light with an UI that suits me and my needs...That's until I can justify buying a SF UBR Invictus!
So I thought I'd share an UI idea that combines two lights I have, and see what you think, and hopefully a manufacturer will pick up on it and make me a light like that!
I currently EDC the Olight S10 Baton. The UI on that works quite well in my opinion for edc use. I also recently got a Thrunite TN12 2014 but I really don't like the UI...To fiddly to select modes...
But combining the S10 and the TN12 might make a rather good UI.
What I want are the following;
*Always be able to instantly get max output from either off, or when constant on in either mode, with tailcap.
*Firefly mode from off.
*Tailcap for momentary on, on all modes.
*Modes; Firefly 0,1-0,5 lumen, low 20 lumen, mid 200-300 lumen, max as much as possible, but at least 1000 lumen!
*Accept 18650/2XCR123
*Kickass runtime
So what I thought of was a light with a side button and a tailcap, just a different UI than I have seen so far.
UI;
(Side button activates the light in constant on, tailcap only activates in momentary on.)
*For firefly mode; press and hold side button from off.
*To change modes; press side button once for constant on (activates the light in previously selected mode, either firefly or the two or three other modes), press again and hold to cycle through the modes. I can accept MAX three modes, low-mid-high. Selected mode will be remembered.
*For momentary on in selected mode, press and hold tailcap when off (not a clicky switch!).
*For max output from either constant on in either mode, or from off. Double tap tailcap. This will activate the max output, you can now push and release the tailcap how fast and many times you want, it will not leave the max output (it will only select max output again if double tapping it). A click on the side button after having double tapped the tailcap will get you constant on in max output.
What do you think? Could it be done? Could it be improved?
I think this would work really well for me, even in a stressed /"tactical" situation. My thought is that if you need max output, it should be easy getting to it with one hand and be able to activate it instantly no matter what mode your currently in or if the light is off. Not having to fiddle with another button or selector ring...
The other modes are not as vital to get to fast.
To all manufacturers that reads this, please make me this light, comment or PM me for further discussions on designs and more specific details
*Kickass runtime
UI;
