twistedraven
- Joined
- Oct 22, 2014
- Messages
- 1,810
So I have an Eagletac D25LC2 with Nichia Emitter, and was quite saddened about the UI. The form factor is great, and the tint of the Nichia is nice (perhaps a little too warm of neutral), but I'm quite puzzled on the UI.
From my understanding, the light has two modes: one with max brightness and a tactical strobe, and one which starts at low, then goes to med and high when using soft presses on the tailswitch.
What puzzles me is that sometimes the max brightness and tactical strobe mode will be activated after the press of the switch, but other times it just stays on all the time even without a press of the switch, and can't be turned off, and I can't toggle between that and strobe. Sometimes if I lightly swing the light against the palm of my hand to give it a shock, it switches modes without even turning the head. Other times, I found that the light seems to have 3 positions on the head, where one is constant on, the other is the 'tactical' mode, and the other is normal mode.
Is this a normality with the Clicky series UI, or is there something wrong about my particular unit?
Edit: just now I've been playing with the light some more, and it seems like the tightness of the tailcap also affects whether or not the light stays in constant brightness or 'tactical' mode. I've never seen the Eagletac manual reference this. Is this how the light is intended to work?
