Woods Walker
The Wood is cut, The Bacon is cooked, Now it’s tim
Very often the bags I actually have within my immediate reach are my dayhiking and overnight camping kits. As I dayhike nearly everyday and camp often this isn't too surprising. Sometimes these dayhikes push into night. Often I will use lights when on the trail or bushwhacking. In some ways these bags double as BOBs. After all one never knows when an emergency will strike. If so it wouldn't really wouldn't be an emergency. These pics were taken during a 9-mile dayhike through rough country. Sometimes when looking to cover a great deal of ground in the shortest amount of time I will take a lighter pack. Best to mix up training IMHO.
First my dayhiking lights. I usually get a late start so can expect to hike into the night during "dayhikes". Here is the gear packed down. The headlamp is within a small foam old school cellphone case a flashlight within the daykit's PSK.
This setup has seen multiple reditions but the theam is the same. A small single battery headlamp with single battery backup. The headlamp is a Fenix HL50. The flashlight a FourSevens QPLC. Both headlmap and flashlight can take either CR123s or AA. There is an AAA to AA adapter. For extra batteries I have 2xCR123, 1XAA LSD NiMH and 1XAAA LSD NiMH.
Right now this is setup for AA but during winter I will use CR123. Why? I like the multi battery options. I like that everything uses a single battery. I like that both headlamp and flashlight can be very bright or very low. The mid levels work good for walking. The setup has enough or as little power to get the job done.
My overnight/multi day warmer weather LED light kit.
Packed.
Unpacked.
The Fenix HL30 and FourSevens 2xAA mini use the same battery configuration. Good runtime and more than enough power to night hike to camp for a good number of miles then setup in the dark if necessary. I did run a 1XAA mini but purchased a 2XAA. The weight really isn't more as I carried an extra battery anyways so why not store that within at the light. Also it locks out naturally once turned off. One negative of both Fenix headlamps is they don't lockup to prevent accidental activation though so far that hasn't happened. Good low mode on the 2XAA mini, seemingly brighter low on the HL30 but a useful amount of light and can be hiked on medium.
The Nitecore headband has came into use so many times as a backup headlamp. The 2XAA mini is a new addition but like the 1XAA mini it fits the headband well however has more output and longer run times which isn't surprising. The DIY diffuser makes a nice hanging lantern. There are 2 AAA to AA converters. Extra batteries are in the camera case. The camera, GPS and radio also use 2XAA. I don't always carry those other electronics but it's nice that everything is on the same page.
In field use.
Relative pros and cons.
1. The HL50 is cold to wear because of the all metal construction which includes a metal holder. I need to wear it over a thin hat in cold weather.
2. The HL30 has long runtime which is good because the battery door is so tricky to open. It would be very hard to do on the move in the dark IMHO. Very comfortable to wear.
3. Common battery types are adventitious. Common battery types among multiple gear items more so.
4. The headlamps both have fantastic beams for working around camping and hiking though the HL50 has more throw.
5. Prefer neutral tints but only one light out of both systems has it. So what does that say.
6. I am not comfortable packing lights which can't be locked out but so far not an issue.
7. Both kits can easily be transferred over to Prep or ER needs.
8. The HL30 drops it's low mode when using lithium primaries.
9. The QPLC using CR123 is amazingly bright on turbo and very very very low on firefly. Works great with AA as well.
10. The 2xAA mini is very bright on high but being a twisty it's a PITA to change modes when put in the headband.
Packed.
Unpacked.
In field use.
