But I will ask, is there a way to combine the increased run time technology with a lower power output, in effect doing just the opposite of what the manfacturers are doing.
I know I'm very simple in my thinking. Please forgive me.
Can you use a lower available setting? As an example, a light has the potential of 1000lm. Run the light at ~500lm. Wouldn't that do what you suggest? If out in the field, are you able to carry an extra battery or two? What am I missing?
Each of my lights has various settings. I don't use the highest settings but it's nice to have the readily available output when needed. What sort of lights are you using?
My current go to house light is the EC4 and it's run-time is tested using 2600 mAh batteries. I use 3400 mAh batteries which increase the run-time by ~31% This increases the run-time from ~90 minutes to ~117 minutes. If I step down from 1000 lm to a more usable 240 lm, using 3400 mAh batteries, the run-time goes up to almost nine hours. If I want or need more output, I use a more powerful light such as a TM16, which uses four 18650s.
Currently, along with others, I'm waiting for the already announced EC4S to be released. It's suppose to have +2000 lm capability. If using two 18650 batteries, this would expectedly make for a shorter run-time. I'm okay with this point. Can you fill me in on what I'm missing?
