I am looking for a suitable rechargeable 123 LED flashlight to use as a cap light. Right now, I have been considering either the Olight S10R Baton or S10R Baton II. At first glance, I would be inclined to get the newer II model because it is rated at 500 lumens vs 400 lumens of the earlier light. However, I would be inclined to use the light for longer periods of time. It looks like the II version drops to 300 lumens after 4 minutes vs. a steady 400 lumens on the earlier light. The other issue, of course, is run time. Certainly longer run time is also desirable. The work around could be to carry a spare charged battery. Would other RCR123A offer much higher capacity than the 650mAh cell that comes with either the S10R Baton or S10R Baton II?
Typically, I would use this clipped to my baseball cap when out horseback riding or hiking. Would the clip on these lights be strong enough the hold the light on a cap? Are there other lights that I should be considering? I want it to be small, thus the RCR123A choice. I want it to have a clip. And the higher lumen output and longer the run time the better.
