Hi everyone, I have several questions regarding Convoy S Series xm-l2 nanjg 105c 3amp build:
1. Is there a significant difference in beam between S2 and S2+ because of S2's deeper reflector?
2. S2 has smaller pill but it also has some small fins. S2+ has bigger pill. Does it make S2+ better for heatsink because of longer pill thread contact with body? (I would also consider adding random little chunks of aluminium to pill, if it would make any difference at all)
3. S2, S2+ has brass pill and newer S3 has integrated aluminium shelf. Is a difference in heatsinking big and does it make harder to build light with integrated pill?
4.S2 is 8.78 dollars on fasttech, S2+ is 12.12 and S3 11,43. Which is best value considering these 3 questions above?
5. Maybe someone had tested, how long best option out of these (or my hand) could survive until running too hot at 3 amps (let's say 18 degree celsius, medium wind)?
Thank you for your time
