Hi,
I'm a complete newbie when it comes to flashlights, but I have a Wolf Eyes that I bought in late 2006 or early 2007 that I can't seem to find very much information about so I figured I'd ask here. I looked through the different forums and I assume this is the best place to ask...
So, it's a Wolf Eyes, 6PX according to the box, Explorer according to the print on the actual flashlight. It has a 6V xenon bulb 26.5 mm diameter (with no larger "outer" spring) and runs on two cr123a. Non removable tail cap with a click switch ("half press" to shine until release, click for constant on).
I can find only one WE 6V xenon bulb online, which is 100 lumens so I assume that's the one. On wolfeyes.dk it states it lasts for an hour.
WE have a 285 lumens LED module with four modes, but I found it a bit expensive since I'm exploring this interest and would rather purchase something cheap at first and move on to more expensive quality parts if/when I decide this is for me. So I purchased this online: https://m.fasttech.com/p/1053100
But then I stumbled upon a post where someone said WE usually don't take "standard" P60/D26 modules. Am I "stuck" with WE modules only, or is there another generic (or at least cheaper) alternative out there? Is there a way to make them fit anyway?
I think I've managed to understand the importance of not using a larger 3.7V or two smaller 3.4(?)V for the 6V bulb, but I'm scratching my head when it comes to effect. Example: a 100 lumens 3.7-6V LED drop-in, will it give 100 lumens both with a 3.7V battery and two 3V batteries? If so, is the difference how long it lasts before it's time to change the batteries?
Regarding the batteries, I've seen everything from 800 to 4000 mAh, is this something that one has to be careful with when it comes to flashlights, or is like with computers, battery packs etc where the mAh is simply how long the battery lasts for? If it's the latter, which capacity batteries are used when stating "this module lasts for x minutes"? For instance, will I be able to use the flashlight for five times as long using two 4000 mAh batteries than if I'd use two 800 mAh batteries (assuming the error rates, real effect etc is linear)?
Im sure these questions are about as basic as they come, but unless I ask I won't learn
