Thanks. Ive fully charged the cells and it does hit turbo but drops to high after 10 seconds. It has a audible rasping sound coming from the light on turbo... What is that?
Oh never mind I've discovered it's induction whine and harmless should have searched first.:shakehead
Thanks again
The TK70 draws around 10 amps at full output - that's about a 15 minute discharge rate for a 3000 mah cell. Because of all that chemistry inside, batteries perform better when slowly discharged, over a couple of hours. Your TK70 won't really be happy until you can get some good 10,000 mAh full-size D cells for it. Even then, that's a 1 hour discharge rate and only good quality cells will perform well.
I've never been able to get my TK70 to full output on alkaline primaries, even buying fresh national-brand cells. Looking at the Energize technical information on their web site, it's not surprising when you realize even a good alkaline D cell has a considerable internal resistance that's not really compatible with delivering 10+ amps.
My least favorite feature of the TK70 is that on low or under-capacity batteries, it will get hung up in one mode and stay there. It'd be nice to toggle between 20 lumens and 300 when running on alkalines, but going round the circle will eventually get you stuck in the highest mode the current load of batteries can support....and there you stay.
Love that light, it's an insane amount of light for something you can carry around with you - literally as much light as a car headlamp.
Bill
