Hi
lightryko,
:welcome: I presume you are comparing the Klarus RS20UV vs the NiteCore CU6? These are 2 very different UV lights.
Firstly, it is important to know what you intend to use the UV for?
This will influence the wavelength of the UV as well as the power of the emitter needed for the task.
Important considerations:-
1) Depending on where you get either, the Klarus is about twice to 3x the price of the NiteCore (See point 2)
2) The Klarus RS20UV uses NichiaUV emitters, which probably accounts for the majority of the cost (I might be mistaken, but they do look like Nichia's NCSU033B). - The best quality emitters around as far as UV is concerned. Klarus specs lists it at max 650mW output (though some sites list it at 3W output, which I believe to be erroneous considering the cost of a 3W Nichia UV emitter). NiteCore lists theirs at 3W output.
3) The RS20UV is a primary UV light - uses the said Nichia emitter in the primary, deep reflector. Secondary RGB+white through the side window akin to a mini lantern of sort. The NiteCore CU6 uses double reflector wells housing the UV and XP-G2 with secondary 5mm red/blue LEDs flanking them.
4) Klarus of course has its magnetic in-light recharging in the RS20UV , like its non-UV cousin. Caveat, of course, being that you need to use their proprietary 2600mAh cell to do that.
So there, if you're considering lower output options for off-the-shelf lights, there are others, like the NiteCore P20UV and StreamLight NightCom UV. Another option is P60UV modules.
Hope this helps!
Remember to use eye protection at all times when using UV emitters.
