GarageBoy
What's a flashlight that comes from the factory with a high cri LED? Is the nichia 319 more efficient than the xpg in my quark mini hi cri?
D25LC2, …. D25A2
great options,
High CRI Nichia: 204 lumen, and 129 lumen high
Low CRI XPL: 430 lumen, and 211 lumen high
2xCR123a, … are still considerably brighter than your typical 1xAA/1xAAA Nichia fare
the 2xAA Eagletac D25A2 Nichia 219…. considerably brighter than 1xAA/1xAAA Nichia lights.
I was saying that the D25LC2 with Nichia has roughly the same brightness as the D25A2 with XM-L2.
I was interested in the Eagletac D25C but have seen notes that if you use RCR123 (16340) you lose the low and medium modes since the operating voltage isn't up to Li-ion levels. Something to keep in mind.
16340 usually refers to RCR123a's, rechargeable CR123a's. They have a higher voltage and lower capacity than primary CR123a's.
your post is confusing me, due to some typos? can you link to the original info "notes" you have seen?
I do not think the Eagletac lumen specs are for 16340 Li-Ion, I think they are specs for CR123, am I mistaken?
terminology:
16340 loose the lower mode
Cr123 … get all the modes
Yeah, the D25C is rated only for CR123
