HighlanderNorth
This may seem a strange question, but it'll make sense soon..... Here's an example: I was at a client's home yesterday working, and he asked me if I could take a look at his recliner chair, which was broken yet again. Its not old, it just has really weak fastners that hold high stress parts together. It has a retracting footrest, which is attached to the underside of the chair with a metal bolt with a plastic nut. Worse yet, the plastic nut also acts as a bearing. So it was really just a matter of time before the soft, plastic nut wore out, cracked in half, or stripped right off the bolt. For the most part, all 3 things happened!
I'd replaced a nut on that side a few months ago with new metal bolt, washer and nut. However, the client had an authorized chair repairman look at it afterwards, and he was supposed to have replaced my work with properly designed & fitted fasteners. He charged $80 for it, but all he really did was loosen my fasteners and claim that he repaired it!
So after he loosened the fasteners I installed, they came loose and fell off. That was the new problem I dealt with yesterday, by installing a 2nd nut over the first, to lock them together(didn't have a lock nut).
But in order to be able to see what I was doing in there, I needed my Spark SL5 220cw to be pointed directly at the dark underside of the chair. As is often the case, I needed both hands to work, and there was nowhere to put the light where it would point in the right direction, except in my mouth.......
Fornunately it's a small AA light that I can hold between my teeth. I do a lot of mouth-holding with my Spark, and previously with my old/lost Zebralight SC-52 that I edc-ed for 3 years, and the Jetbeam BC-10 before it. Sometimes I'll hold the light in between my teeth long enough that my jaw muscles become sore.
This information may make it a bit harder to sell my Spark here in the future if I ever decided to sell it! That won't happen anyway. Does your primary light end up in your mouth?
