SuPpAvIlLiN
Hey guys. I am wondering what the difference between 3 LED's on a star vs 3 separate LED's. Besides space, what are the advantages of having 3 LED's on the same star?
I'll try to answer you in parts as I'm in the bus now.
The best thing would be to go to YouTube and type series vs parallel for a good explanation. It's quite hard just in words without pointing to a diagram.
In series the electricity passes THROUGH one led to another. If one led malfunctions it could open the circuit (open circuit means it's not all connected up, electricity can only pass on closed circuit. Think of it like a water hose. It it's all connected then water will get delivered to the end of the hose (closed) if the water pipe is open (cut anywhere in the middle) then you won't get water delivered to the end of the hose)
In parallel the electricity passes FROM one led to another.
I'm not sure if I explained in a very clear way.
The advantage of parallel is that I you burn one of the led then you will still provide current to the other two. Which in series I one led burns then the three led will stop working as there is an open circuit.
I would personally go in parallel. But then you have to provide three times more current them series. (But you only need to provide the 12v instead of 36volts).
Advantage of series is that you don't need as much current, just need higher voltages.
Let me see if I can explain to you simple.
Series = current stays the same but for every led you need to add the voltage. So three led would hav the 2amp current (not changed) but it's 12v + 12v + 12v. For a total of 36 volts to operate the led in the 3000lm for each.
Parallel = voltage stays the same (its opposite to series circuit) but the current adds up. So for three leds the operating Voltage is 12volts but the current is 2A + 2A+ 2A for a total of 6amps to get the 3000lm.
i gotcha, no optics and the dies are pretty big for the star. I am haveing a light built with 4 XHP-70's and just wanted to make sure I was doing the practical thing with 4 singles. My goal was basically the brightest thing possible to light up this property at night. from what I gathered 4 single XHP-70s is the best route to go for that goal.I would say that it's just a matter of time before you do.
I can't see the XHP50/70 showing up in a tiny 20mm star as the optics don't exist either and the density would be pretty tight. I could be possible to find them in a larger 30-40mm triple mPCB. There are some larger triple optics which would probably work much better with the larger LEDs.
I'm sort of going for I guess I'll call it projected flood, I didn't want a consintrated hot spot that bright and I didn't want pure flood either so we went with narrow beam optics. I'm not sure what driver we are using, I went with x3 32650's.That will definitely put out a lot of light. Will there be four separate reflectors, one for each LED. Or, will it be a 4-welled single reflector to blend the beams?
How do you plan on driving the setup? Battery and driver config.
i wanted a hand held for this one, it won't be too compact, needed a decent size head for those 4 LED's/optics and heat sinking.If you just want to light up a property, why not try the 100w COB led. They produce 9000-10000lm each. Put a few together and you have a wall of light.
Unless you want to create a compact flashlight?
