How do nichia compare to cree in lumen output? Not that I'm over fully fussed just curious as info I see only shows at 0.7A draw compared to 2.8A draw for Cree. I'm just after reasonably bright, good natural light quality over a moderate distance (100-150m)
As an example, my 219B in an olight m20 smooth reflector, fires the hi cri beam considerably further than an xml2 in a smaller light. Lots of variables for the throw side, look at what the deft X can do with a nichia !
Nichia 219b is good for maybe 400lm tops
Nichia 219C is good for quite a bit more(not sure exactly but can be driven quite a bit harder than the B! which puts it near CREE.
In the c8, a 4000k or 5000k xpl HI would work nicely..............
imo the nichia 219b is suited more for closer up uses due to output/rendition................we loose our colour vision in the dark and at distance.
So far i would lean to a 219C for what you want, nice 5000k tint(can get 3000 and 4000k and 5700k iirc in the C flavour too). Host/reflector is key to your beam, so not too deep/wide for a too concentrated hot spot, and to retain some bright spill.
A good example would be the r50vn, this is a shaved dome xhp50 in a wide but shallow reflector.............real useful beam! Very broad spill, around 40kcd throw, which tends to be enough for a pocket able light/type uses for most. So a good all rounder ............just an example.
