Two Arc 4+5 questions (maybe 4 ?\'s)
I hope I didn't miss the answers elsewhere.
Will the Arc 5 work with 1 123? At reduced output of course.
I asked this question before but will extend it a bit. Could you use a twisty on an Arc 4/5? Set level you want with switch and then quickly change to twisty? My understanding is that the settings will be retained if the electrical contact is only lost for a little while. And then the switch in the head could be activated with twist action. This would give a light you could set and then have a smaller package to carry. one more question--Could you do the twist quickly on/off/on to access other functions? Is there a picture with an Arc LS w/twisty, Arc LS w/switch and Arc4 (maybe inbetween?).
Thanks in Advance!
Thanks in Advance!
