Re: getting a tight beam using a fraen lp (lux III
Actually, the Fraen LP and the full sized Fraen have very similar beams. The full sized Fraen has a more round beam though.
The Fraen LP is what it is. It's a very good optic for small lights. If all the space that you have is enough to accomodate an optic, then you have a small light and the Fraen LP and the NX05 are probably the only choices that you have. A reflector the same size of the Fraen LP, won't get you more throw. In fact, it will probably get you less, but you'll have sidespill.
Simply put, the Fraen LP will NOT make a light a long distance thrower, in comparison to, say, a PR equipped light. It will make for a very good medium range light that will put lots of light on the subject. In my neck of the woods (meaning suburbs with lots of ambient lighting) the Fraen LP does well out to 40 yards or so.
If you want more throw, go with a light that will accomodate a PR. If size is not a concern, then a
M@g reflector is in order.
