Flashlight for power emergencies and attic/basement DIY work
CBET
Hi all,
Looking to get a couple of flashlights for power outages and various house work in the attic/etc. Must be reasonably durable for dropping 2-3 feet on ground/concrete, waterproof, and dust resistant. Will use rechargeable AA batteries (have a bunch of Eneloops in various devices, have multiple chargers). Would prefer longer runtimes, so probably two AA's rather than one.
____I would like to purchase the light in person from a brick and mortar store. I am located in ______________.
_X_ This will be mail-order or Online (location doesn't matter).
2) Budget: An easy question, but you may change your mind after answering the rest! :)
____I don't know yet
____Up to $25.
_X_ Up to $50.
____Up to $100.
____Up to $200.
____Up to $300.
____Essentially unlimited.
3) Format:
____I am not sure, please help me decide.
_X_ I want a flashlight (hand held/self contained).
____I want a self-contained headlamp.
____I want a headlamp with an external pack/power source.
____I want a mounted light (typically for a bicycle or vehicle)
____I want a lantern/area light.
____I want a portable spotlight (it may have an external power source).
____Other ____________________________________________
4) Size:
____MICRO - Keychain size.
____TINY - Every day carry (2-4 inches).
_X_ SMALL - Every day carry (4-7 inches).
____MEDIUM - Holster/belt ring carry. (>7 inches)
____LARGE - Big enough to need its own travel case.
____I don't know/I don't care.
5) Emitter/Light source:
_X_ LED (known for efficiency, longevity, and compactness)
____I don't know.
6) Manufacturer:
_X_ I want to buy a light from a large/traditional manufacturer that is ready to go out of the box.
_X_ I would like a light from a specialty manufacturer (Possibly limited run/Custom).
____I am interested in assembling my own components. (for example a "host" or flashlight body from one manufacturer, and a "drop-in" emitter from another source).
____I intend to use "Primary"/Disposable Alkaline batteries based on the usual AAA/AA/C/D sized cells common to most stores.
____I intend to use "Primary"/Disposable Lithium batteries based on the usual AAA/AA/C/D and CR123 sized cells common to most stores (often a cold weather or long storage choice).
_X_ I intend to use Rechargeable cells (NiMH or NiCD) based on the usual AAA/AA/C/D sized cells common to most stores.
____I intend to use Rechargeable cells based on less common formats (18500 or 18650 Li-Ion, RCR123, et-al).
____I want a light with an integrated rechargeable battery pack.
____I don't know/I need more information on power sources.
____I want a light that plugs directly into the wall (literally with prongs built into the light)
____I want a light that has a recharging adapter (your typical "wall wart")
____I want a light that snaps into a cradle (usually mounted on a wall)
_X_ I want a separate/stand-alone charger (this involves removing the batteries to charge)
____I don't care
____I want to navigate a dark room or read a map (1-10 lumens).
____I want an indoor "blackout" light (15-50 lumens)
_X_ I want to confidently walk around an unlit/unpaved rural area (60-150 lumens).
___ I want to illuminate my entire backyard or a campsite (150-300 lumens).
____I want to illuminate an entire field, the neighbor's front yard several houses down, impress my friends and neighbors, etc. (300-700 lumens).
____I want search and rescue type illumination (800+ lumens).
____SPECIAL NOTE: Burst/Turbo mode Category - There are several lights that will run at a super bright maximum for a very limited period (usually 5-10 minutes) and then will "step-down" to a lower level for thermal control. Check here if this is acceptable.
____All Flood: I am doing "arms length" tasks like reading and campsite cooking.
_X_ Wide Flood: I want a defined flood area for semi-close tasks like after-dark campsite tasks or working on a car.
____Narrow Flood: I want a sharply defined flood area that will project some distance for tasks like trail walking.
____Wide Throw: I want a beam with a noticeable hot-center for distance throw and a significant amount of "side-spill". Good for rough trail hiking, search and rescue, and general distance work.
____Narrow Throw: I want a beam with a very tight "hot center" and minimal "side-spill". Good for distance viewing, fog, and looking through dense undergrowth.
____Turbohead: I want a far-distance projector with a sharply focused spot of light and minimal or zero side-spill. Good for extreme distance and impressing your friends.
____Less than 1 yard/meter (reading, other close work)
____Less than 5 yards/meters (looking for something inside a dark shed/garage/basement)
_X_ 5-20 yards/meters (check out a noise in the backyard)
____150+ yards (I am searching from a helicopter)
____30-60 minutes (I have plenty of batteries just ready to be changed)
_X_ 90-120 minutes (Runtime is moderately important, but still not critical)
____3 hours + (I critically need this light to run on max for extended periods in between battery changes/charges).
____Not Important (A "night-stand" light).
_X_ Very Important (Camping, Backpacking, Car Glove-box).
____Critical (Police, Fire, Search & Rescue, Caving, Survival).
____I don't know.
____Any size switch will do.
____I need a BIG switch (I'll be using gloves or have very large hands or coordination issues).
____I want a forward clicky (Helpful for momentary activation and signaling).
____I want a momentary switch (Predominantly for use with signaling and short bursts of momentary light only).
_X_ I want a twisty switch (Tighten the head/tailcap to activate, and the light will stay on until the head/tailcap is loosened).
_X_ I want a body mounted switch (near the head, like on a Maglite).
_X_ I want a tail mounted switch (found on the majority of today's high end lights).
____I want a remote switch (usually found on high-end bicycle headlights)
____I don't care.
____I don't know.
____A simple on-off with only one output level is fine for me.
_X_ I want 2 light levels. (Brighter/short runtime and Dimmer/long runtime.)
_X_ I want multiple light levels. (Some lights have 5-16 light levels.)
____I want a selector ring.
____I want a strobe mode. (Oscillating pattern to confuse/blind aka "Police Mode")
____I want SOS mode. (blinks in ...---... emergency pattern)
____I want a beacon mode. (Regular flashes at full power to show location.)
____I don't care.
____I don't know.
14)Material/Finish/Coating
____Anodized Aluminum – either type II or III (Hard Anodized) (Aluminum, specifically HA, is the most common material/finish for today's higher end flashlights).
____Stainless steel (durable, but much heavier than aluminum)
____Titanium (durable and nearly as lightweight as aluminum, but can be moderately to significantly more expensive).
_X_ I don't care.
____I don't know.
15) Water resistance
____None needed
____IPX4 (Splash resistant)
_X_ IPX7 (Waterproof to 1 meter/30min)
____IPX8 (Submersible to greater than 1 meter for 4 hours)
16) Storage conditions
_X_ In house (temperature/climate controlled environment)
____Emergency kit (long standby periods)
____Automobile glove-box (wide temperature swings, long standby periods, critical reliability)
____Other_____________________________________________
_X_ Not too cold/blue light (maybe 3500-4000K), reasonable high CRI so easy on the eyes
xxo
Sounds like the 2AA Energizer hardcase Task light would be good for this application.
We have a recent thread on this over in the budget forum:
https://www.candlepowerforums.com/v...-Hardcase-300-Lumen-2AA&p=5339769#post5339769
LeanBurn
Alberta
Have you tried the Parametrek flashlight guide?
Just plug in the values you are looking for and it lists them. Some would be:
Fenix E12
Thrunite Archer 1A/2A
Manker E11
PartyPete
If you are looking specifically for a 2x AA light, the Thrunite Archer 2A and Fenix E20 are both good.
I've actually had the Fenix for many years and it's an excellent, no frills 2x AA utility light. Very tough and probably seen more drops and water than I can remember and still works fine.
longuylander
I will vouch for the Fenix E20 also. It's a great, straight-forward light. Its only downside for your needs is it is more a thrower than flood. It has decent spill, but a diffuser would help for more light dissipation during indoor use.
LetThereBeLight!
Given what the OP stated, I'd recommend the Lumintop Tool 2.0 with a 14500 battery in it, one that Nitecore makes that has the port to recharge it built right into the battery itself.
The Tool 2.0 would of course also run on AA batteries.
- LetThereBeLight!
Whitehawkup
I also will vouch for the lumintop tool AA 2.0 with a Nitecore 14500 micro-usb rechargeable battery. Lots of light in such a small package. And even if for some reason you have to use regular AA batteries, you would have slightly longer runtimes and still have more than enough lumen output for your needs.
LeanBurn
Alberta
I agree with Poppy.
Hands-free lighting is indispensable and very underrated. When I know I am going to have to work with my hands, I only reach for headlamps.
If you were to try out Parametrek flashlight tool it can accelerate your search by quite a bit.
CBET
Thank you everyone, I ended up getting Thrunite Archer V3 and Energizer Headlamp. Also got a pack of Energizer Hardcase flashlights to give away as gifts this holiday season.
