asdalton
I recently got and EverLED drop-in, and I have found that it works very well in this Energizer Contractor Work Light. This light has both a 2AA and a 2D version, and I have the AA version. It's quite large for a 2AA flashlight, and some people may balk at the size. However, it has a nice large reflector (as big as many C or D flashlights) that give a strong hotspot with a smooth surrounding corona. The reflector is partially faceted and partially smooth. The pushbutton switch is very easy to use. An additional bonus is that the bulb is held in place by a broad aluminum cap, which conducts a lot of heat away from the EverLED.
The EverLED gives good output on the two AA cells, but right now I'm getting slightly brighter output with three N cells. I had to tape the N cells together and make an aluminum foil extension to do this, as you might expect. I have already checked the battery compartment and found that it's wide enough to accommodate four AAA cells in either a series (6 V) or 2x2 (3 V) arrangement. It may even be possible to cram 8 AAA cells in there. The only necessary modification would be to construct a battery carriage with the appropriate length and wiring arrangement.
I imagine that the 2D version could accommodate similar arrangments of AA cells.
Does anyone else have a favorite host light for their EverLED?
