Justintoxicated
I got my replacement leadlight laser today and it pretty much does the same thng as the last one. It is bright for a second then dims and then gets bright again....This one does it much faster than the last one though.
Second I just have this sinking feeling that someone has already messed with the button. The first time I turned it on the button stuck in. But it seems to work fine now. The button is raised higher in the back than in the front. I measured the current with my multimeter and this one is pulling about 320 ma..again just cowincidence or what?
Another thing I noticed is that when held about 1 inch away from the wayy I can see major artifacts in the beam, one is like a wide line where there is no light at all! Looks almsot like there is water on it, the edges of the line with no light are bright. When I point it about only a few feet from the wall there is the normal white spot and another dot off to the side that is very dim...
Is it typical for leadlights to have these artifacts because I did not notice them in my old one.
Appreciate anyone who looks into this...perhaps I am just too picky or something,
Thanks..
Thanks..
