ElektroLumens
Fellow CPFer's,
I recently mounted 2 Luxeon Star's on a relatively large heat sink, and wired them in series. I powered them at 6.8 volts, using 8 AA batteries (12 volts), and a switching step-down regulator I put together using the LM2595 IC (supposedly can get 95% efficiency). I have to tell you the light being put out is very impressive. I am thinking I might like to put together a flashlight using 2 Luxeon Star's, with the optics. I would probably wire the Luxeons in parallel at 3.2 volts, and use either 4 AA's, or 8 AA's. The current draw would be about 700mA, about the same as a 2 'D' cell incandescent flashlight. However, the quality of light thrown is much better, although maybe not a beam that will throw as far. With 8 AA's starting at 12 volts and dropping down to 3.2, the batteries would be completely expended. If rechargables were used, the 12 volt to 6,8 volt configuration could be used.
Any thoughts on this flashlight configuration. I am thinking to call it the 'Luxeon Double Star'. ?? Perhaps there could also be a 'Luxeon Triple Star', using 4 to 8 C batteries?
I used to think, Why bother with multiple Luxeons, when they will use equivalent current as an incandescent light bulb, but after seeing this high quality, extremely bright light, I really like it.
