Re: what\'s the closest thing to a rechargeable SF M6?
[ QUOTE ]
Billmanweh said:
[ QUOTE ]
Prolepsis said:
Jim's modded TigerLight produces more light than my SureFire M6 in a ceiling bounce test. /ubbthreads/images/graemlins/cool.gif
[/ QUOTE ]
Now THAT'S what I'm talking about! Is it a turnkey set-up?
[/ QUOTE ]
Yup. Basically, you replace the stock plastic lense, the battery and the lamp assembly--you just have to remove the old stock parts. Easy to do.
There is one other bit, however. The Tiger85 requires that you send in your charger for modding--that's the only extra part. Jim also makes different Tiger mod packs that don't require the charger to be modded. If you go through the link I sent you, it'll tell you all that you need to know. /ubbthreads/images/graemlins/smile.gif Basically, the Tiger85 is the mod for people who want their TigerLight to be as bright as possible, no matter what.
I should clarify that the Tiger85 is brighter than the SF M6 running the HOLA(!!) on fresh batteries. Just a smidgen brighter. /ubbthreads/images/graemlins/smile.gif But it is also heavier than the M6.
Kind of hard to explain, but the M6 is still dang impressive.
