D
**DONOTDELETE**
Guest
After a very long time on used batts, 20 min use each day, the low batt led lit.
Somewhere in the low batt range, the Opalec circuit made a humming noise, almost like something very small was vibrating a little.
Later in the low batt range, the noise went away. I suspect the noise will be generated reliably in a narrow batt level.
Light output is still useful at this level.
What does it mean when a circuit makes a noise at a certain voltage?
