Dorcy Solid State flashlight at Walmart ... $8.00 (same as Turtlelight I.
Very easy to convert to a Luxeon Star led by cutting out the lamp side of the reflector to just accomodate the Luxeon, then removing the side contact from the lamp holder and cutting down pr2 size socket so that the Luxeon board will fit under the two retaining arms of the lamp holder (notch the Luxeon board to fit). Wire in the Luxeon in series with a 10 ohm 1/2 watt resistor.
Current draw with the 6 volt power source is approx. 250 ma. ... Very bright.
