unclearty
I picked up one of these for short money. First..horrible beam with bad rings...the emitter is too far below the refector. Second..flickers after a minute or two.
First issue involves disassembly..these have some epoxy on the threads for the head. Get 2 hose clamps..the type with worm screws. Wrap a piece of rubber around the head and apply a hose clamp. Do the same for the body. Place the light..body down..lightly in a vise. You do not need to clamp down on the light...just prevent it from turning. Then..using some large channel lock type pliers..GENTLY twist the head. It will break free and unscrew without damaging the finish. Remove the reflector and place an oring between the lens and reflector..trial and error here. The object is to lower the reflector around the emitter. I now have a VERY nice, white beam..soft edges and nice spill...no more ugly rings. Second..remove the battery holder..remove batteries. Gently, using a small screwdriver...stretch the springs straigt up. By lenghtening the springs, you're making better contact with the positive terminals. This little light now works very well and is my current edc.
Unfortunately, I'm at work and no camera available.
