Where did you get these /ubbthreads/images/graemlins/huh.gif /ubbthreads/images/graemlins/huh.gif /ubbthreads/images/graemlins/bowdown.gif /ubbthreads/images/graemlins/popcorn.gif /ubbthreads/images/graemlins/confused.gif
If the throw is identical, you are saying that these two LED's being compared would have the same lux reading. Very interesting! /ubbthreads/images/graemlins/thinking.gif
The ceiling test certainly is in line with a U flux compared to a T flux. Ceterus paribus, I would have expected similar beam shapes but more intensity of light in both the reflected spot as well as spill. /ubbthreads/images/graemlins/icon3.gif
Yes it would raggie. Henry from HDS mentioned that LED's and their brightness fall into a normal bell curve. What the standard is now(the middle of the curve) determines how many of these awsome bins there are. If the S flux bins are the normal bin for Luxeon III's, then there probably aren't 10,000 U flux binns available right now. Probably with the recent and continuous improvements LED's eventually U bins will become readily available and as easy to obtain as an S bin is today. Chop I belive mentioned that you needed to buy at least four reels of 100 to get lumelids to discuss certain bins
