Skibane
Just received a brand-new Q-III via ebay, and am very dissapointed with the output. It simply isn't as bright as my 1 watt Sharper Image (also built by Nuwai) single-cell Luxeon. The Q-III has a tad more side spill, but doesn't put out as much light (either in the center of the beam or several degrees off-center).
I measured the Q-III's battery voltage (2.995 volts - essentially brand-new), and also measured the current draw (800 mA, versus 600 mA for my SI 1 watt). Bottom Line: The Q-III is dimmer, even though it's drawing more current.
Defect? Luxeon lottery?
