BuddTX
This is a re-post, but I just had to be the first to post a topic in the new forum, SPOTLIGHTS!
(Thanks for adding the new forums!)
When my interest in flashlights re-awoke, my first two purchases were spotlights, not flashlights.
Also check out this post for some interesting stories of using the "big lights":
http://www.candlepowerforums.com/cgi-bin/ultimatebb.cgi?ubb=get_topic&f=1&t=001451
So, here it is, "the best of" sort to speak!
I can't tell you for sure the "BEST", because that implies that I have tested every one of them.
I've owned a 1 mil CP Vector
Gave my brother-in-law a 3 mil 2 bulb CP vector
and I own a 2 mil CP Optronics http://www.cabelas.com/cabelas/en/templates/product/standard-item.jhtml?id=0013216514204a&navAction=push&navCount=0&indexId=&podId=0013216&catalogCode=IC&parentId=&parentType=[/UR L]
Of the three, I liked them all, but the one I like the best was the Optronics.
I understand that LSI is very good also. Check them out.
Vector 1 mil CP - Cheap, bright but uneven beam, (some shadows and not even) but at this brightness, shadows are not a problem. Locking ON/OF switch that can be locked in either position. My model did not have a stand, but some now have a work light and a tripod stand built in. Can buy these at Target.
{edit} With 1 mil cp, and up, I think that "shadow" is a bad term, maybe, "not as bright as the bright spots, spots" <grin> Get the idea?
Vector 3 mil CP 2 bulb. - Bright (duh!), has 2 "blue bulbs" but does not appear like the cheap blue bulbs that you see on autos these days. Nice white light. More even beam - large coverage. Heavy. Will stand by itself. Has a "work light" that will give off light for hours. Also has a 12 volt cigarrette lighter plug to actually power other 12 volt devices! Can operate with one or two bulbs. Wish the head was pivitable. NO locking ON/OFF switch. (my model anyway). Target sells these for over 20 bucks LESS than what I paid before Christmas (Target price - 40 something dollars)
Optronics 2 mil CP - Very even, wide, VERY WIDE, beam. I actually like the light of this light better than the Vector 3 mil 2 bulb light. I think that the beam is just as bright, and even wider than the 3 mil vector. NO STAND. Locking ON/OFF switch. Removable battery. Can be used (if the battery is removed) plugged in to the car cigarette plug. Not too heavy to carry around. Again, VERY WIDE, BRIGHT, EVEN SMOOTH LARGE BEAM. I know the CP rating can be swayed into a larger number by creating a very narrow, tight beam, but this is not the case here. Hard to describe how big, even and bright the beam is, it really has to be seen to believe!
I bought my Optronics from Cableas. Target sells Vector, so you could always go there, buy a couple, and keep them if you like them , or return them.
I remember when I got my Vector 1 mil CP light, it stunned me with the brightness, but after getting the 2 mil Optronics, the 1 mil Vector did not impress me as much.
Any one of these is going to have 20-40 minutes of light. You can buy spare Lead batteries for the Optronics, so you could buy multiple batteries, and charge them all up if you needed more power, and you had a way to carry them.
The Optronics also has an option to remove the battery, and power it from a cigaratte lighter.
