WildRice
well the white LED zip-light was first, now there is a RGB (selectable) zip-light. The LED is a 4 leg RGB LED from HK. The driver was out of a dollar store lighted wand. The board has a diode and cap to hold the voltage long enough for it to change sequence when the power is off for a short time (1sec or less), by pressing the lid button. When first open the LED goes through a 15sec sequence then goes to green, tapping the button one turns it off, the next tap turns on red. the sequence is...
(power on, 15seq seq, g,off,r,off,b,off rb,off,bg,off,rg,off,rgb,off,sequence).
It runns on 2x cr2016 button cells.
Jeff
Jeff
