3rd_shift
Are you still playing with your sn2, or sn2 clone, or 2c mag with 6 cell bulb and going through cr123's like crazy? /ubbthreads/images/graemlins/crazy.gif
Now there may be a better way. /ubbthreads/images/graemlins/ooo.gif
Here is the nonrechargeable power source with cutdown spring
below with an sn2 clone with a 5 watt Luxeon led lurking inside.
A better, rechargeable and longer runtime source below.
2 18650 2200mah rated li-ion batteries with international charger.
Special thanks to; cpf'er AW in the Non Lights BST forum. /ubbthreads/images/graemlins/thumbsup.gif
Oh no!! They don't really fit. /ubbthreads/images/graemlins/ohgeez.gif /ubbthreads/images/graemlins/mecry.gif They are much too long. /ubbthreads/images/graemlins/mad.gif
/ubbthreads/images/graemlins/jpshakehead.gif
Hehe, problem solved easily enough below. /ubbthreads/images/graemlins/wink.gif
The dremel (bottom) was used to expose some bare aluminum at the bottom of the tailcap.
I found the top part of the cutdown spring and used it inside the tailcap after customizing it with the vise pliers (top) to make good contact.
Placed it inside the tailcap with a little contact grease.
Below is a pic of the leftovers of the old setup.
The bigger diameter 18650's also made for a still loose, but better fit inside this "Goodyear" brand battery adaptor inside the light.
The same one used for the cr123's. /ubbthreads/images/graemlins/wink.gif
Still pulls 850-900 milliamps from these just like from the old 3X cr123 setup. /ubbthreads/images/graemlins/icon3.gif /ubbthreads/images/graemlins/wink.gif
The new setups gains:
Rechargeability for your sn2 clone.
Higher capacity, and longer runtime than the disposable cr123s had. /ubbthreads/images/graemlins/happy14.gif
The unit modded here is resistored unlike a real spaceneedle2. (no sweat)
Not sure what these batteries will do with an unresistored sn2. Please use care with this mod with a nonresistored sn2, or sn2 clone.
Happy modding. /ubbthreads/images/graemlins/smile.gif
Another edit:
The 18650's featured are flat-tops with no added length from tabs, or (+) buttons.
Another edit:
